Beosystem 4500 rust!! Dangerous ?
You have to wonder why the rust is there. Under normal conditions where the audio components are stored in a dry place there would be not rust so I would have to question the environment these components were kept. I recommend removing everything you can, clean all of the rust off the cabinets and metal pieces then repaint them.
In answer to your question though, the rusty cabinet itself isn't dangerous.
-sonavor
yes you’re right, it was kept in a shed or something probably. But maybe it helps to remove the rust, what is a effective way of doing this (not only the cabinet but the electronics that may be corroded). I was thinking if the corrosion was going to be a issue in terms of safety on the electronics.You have to wonder why the rust is there. Under normal conditions where the audio components are stored in a dry place there would be not rust so I would have to question the environment these components were kept. I recommend removing everything you can, clean all of the rust off the cabinets and metal pieces then repaint them. In answer to your question though, the rusty cabinet itself isn't dangerous. -sonavor
The best way would to disassemble the electronics from the chassis/frame. Take lots of photos so you know how things plugged in. You might label connectors on cables.
on the rusty metal pieces the best thing is to sand away all of the rust then clean it really good to remove any sanding residue. After that paint it to seal it back up. If you want to be really professional you can paint it with primer first.
On small pieces like screws, nuts, washers you can clean them up with something like a link or replace the hardware with new screws.
Inspect all of the electronics. They shouldn't have any rust but might need cleaning with some isopropyl or denatured alcohol. Switches will need cleaning. I would use some
You definitely need to clean it, once clean it should be fine although there does seem to be a black spot on the board, not sure what that is.
For all connectors, switches and potentiometers I can honestly recommend Valvoline Contact Cleaner. I have just finished an project with it and all problems have gone.
Okey! How to i clean it without damaging the board?For all connectors, switches and potentiometers I can honestly recommend Valvoline Contact Cleaner. I have just finished an project with it and all problems have gone.
Will definitely do it, will let you know how it goes!The best way would to disassemble the electronics from the chassis/frame. Take lots of photos so you know how things plugged in. You might label connectors on cables. on the rusty metal pieces the best thing is to sand away all of the rust then clean it really good to remove any sanding residue. After that paint it to seal it back up. If you want to be really professional you can paint it with primer first. On small pieces like screws, nuts, washers you can clean them up with something like a rust neutralizer or replace the hardware with new screws. Inspect all of the electronics. They shouldn't have any rust but might need cleaning with some isopropyl or denatured alcohol. Switches will need cleaning. I would use some Deoxit . I hope that information helps. -sonavor
Yes, the inside looks remarkably good compared to the corrosion on the cabinet and frame.
-sonavor
