Hi Guy's,
Well after a lot of trial and error (using all your collective advice), and replacing the IR cable (bad RJ45 connector !!!), I've finally got the system 4 up and running to the point it is now all configured etc.
But I now have another new problem, I cannot 'fire up' any of the sources as I get the following message on the screen:
'Warning, protected content - select another source' No matter which source I choose, I cannot get it to display.
The screen flashes on the source selection (Blue ray, Set top box) and the message disappears for a few seconds but then returns at the top of the blank screen.
Have any of you experienced this and if so, do you know how to resolve this issue???
