Beosystem 4 Product integration & Beoliving Intelligence.
Dear Forum,
I recently bought a Beosystem 4.
When i want to integrate Products i cannot see my Beoloving intelligence in the setup list.
The only devices i can select are the NL/ML Converter and Beosound Moment.
My setup (Network) has the following devices:
- Masterlink Gateway;
- Beoliving intelligence;
- NL/ML Converter;
- BeoSound Moment.
Does anyone experienced this?
Thank you in advanced.
Regards,
Nokhai
Rather than using the settings for product integration, what you want to do is enable the BeoSystem 4 to send LIGHT
My earlier message got cut off.
Rather than using the settings for product integration, what you want to do is enable the BeoSystem 4 to send LIGHT and CONTROL commands. You do this through the hidden service menu, where you enable forwarding LIGHT and CONTROL commands to either the MLGW or BLGW. I can't remember the key sequence to get into the service menu, but if I can find it, I'll post it.
Accessing Customer Service Menu
Press the
MENU
button on the remote control, choose SETUP, and press the
Centre
button. Press
RED
button and within 3 seconds press the
Centre
button
Thank you BeoJeff
Actually i want to to be able to get the BeoLiving intelligence control section on my TV. I was hoping that in this way i could control my scenes (which i have build in the Beoliving Intelligence).
Also I wanted to see the Doorbird Camera on the TV when somebody rings the bell.
My lights are controlled by a HUE bridge, will this be also controlable trough the BeoRemote One?
You need to enable the forwarding of LIGHT and CONTROL commands on the BeoSystem 4 to be able to trigger Hue scenes that are created as macros in your BLI. You'll need to create these macros so that you can trigger them with a LIGHT command. There are several LIGHT commands already built into the BeoRemote One under the LIGHT section. You can use the monitor function of the BLI to detect what these commands are in order to use them as triggers when building macros. Also, you can rename those LIGHT commands on your BeoRemote One.
You need to edit your BeoRemote One so that HOME CONTROL is shown in your "LIST for TV."
You can find some more info here, BeoSys 4 is on the same platform as the V1:
HI Jeff.
Thanks for the information. I was able to get the lights on my BV 12 screen.
Perfect!
Another Question, do you have also experience with the NL/ML Converter?
nokhai wrote:
HI Jeff.
Perfect!
Well, I have 8 NL/ML Converters. So you COULD say that I have some experience with them! lol
