beosystem 4 - motorstand
i plan to change the beosystem 3 on a beovision 9 to a beosystem 4.
powerlink adapter, the monitor and the ir/auto contrast wiring doesn’t seem to be the problem. (found the cabling in the service manual)
but the beovision 9/beosystem 3 has a old motorstand with 5 pins:
1 - GND (Yellow)
2 - Turn L (Red)
3 - Turn R (Brown)
4 - Pos (Black)
5 - +12 (Orange)
and the beosystem 4 has 4 pins with can-bus:
MicroFit 4-pin
Pin 1 - CANL_C Negative CAN bus signal
Pin 2 - GND_STAND Ground for stand
Pin 3 - CANH_C Positive CAN bus signal
Pin 4 - 12V_STAND_C 12V supply for standTMDS.
is there any chance to control the old stand of the bv9 with the 4 pin can-bus of the beosystem 4? a adapter? or maybe change the motor and control of the bv9 stand with motor/control of a newer stand (bv11)?
thanks beoandy
It seems that they may be operating with different control standards. The new setup appears to be using CAN bus for control.
