beojeff wrote:
beoandy wrote:
hi,
you can use any Atlona AT-HD4-V42. there is no specific firmware or version. (info from b&o and atlona support) I use the Atlona AT-HD4-V42 with the beosystem 4 with projector and a upgraded beovision 9 (with deactivated beosystem 3). When the beosystem 4 detects the AT-HD4-V42 on the hdmi output, an additional menu appears for the two hdmi outputs . do you know the service manual for the cinema (2nd screen) installation of the beosystem 4?
beoandy
This is not true. You must have the Atlona flashed with the B&O firmware in order to get the hidden menu of having 2 screens. I know this first-hand. I had the switcher without the B&O firmware and it did not provide the menu until it was flashed with the B&O firmware. This is detected via HDMI.
hi beojeff!
very interesting, i use an original AT-HD4-V42 without b&o firmeware and it is recognized by the beosystem 4 at the hdmi output. thus I get the menu for the second monitor and the ir control via CTRL2 and for the projector via CTRL5. (as described in the manual BeoSystem 4 dual screen)
I also received this information from b&o and atlona support. (there is only one difference in the packaging) - where did you get the b&o firmeware did you flash it yourself or where was it done? (at that time I only made a firmware update from the atlona homepage version S99A)
thanks beoandy
