Anyone know I it is possible to use a BEO4 with the Beosystem 4 - it seems that it will only work with the Beoremote One or the BEO4 with the joystick to me. I've a lot o BEO4s and its a shame if I can't use them.
It is possible. There is a setting to switch to Beo4/5/6. Then, you must assign the sources, for example to DVD, V.MEM, TV, etc.
I’ve tried that. The Go button doesn’t work on the beo4.
Isn't there a setting in one of the set up menus to select Beo4 with or without navigation?
Regards
Opman
Regards
Opman
With Bsys3 yes,there is option to select Beo4 with/or without navi button.Don't know abt Bsys4
No, with the latest sw-versions of the BSys3 (and BV10,8 etc), you can choose between the two versions of the Beo4.
The Beo4/navi can be set to either Navi or old Beo4 function.
I ws hoping I could pick up the Netflix and Prime buttons on the Beoremote one using the connected MLGW, but it seems it doesn't log the keys at all. I suspect the software version of the MLGW is an issue as it was only last updated in 2017.
Would a BLGW be able to read them I wonder.
I had thought the same thing as you did. The BLGW did not detect the the Netflix or Prime buttons. I had hoped the buttons might send out a CONTROL command, but it seems that they do not. I guess the buttons only work with bluetooth.
Interesting. I'll see if they do send out a bluetooth command. If so, I can capture them that way.
