Beosystem 3000, 2000 Wall Mounting
I have finaly amassed a Beosystem 3000, inc. Beogram 3000 and CDX; but how to mount it all to the wall?
Is there a specific bracket, or do you simply put screws in the wall and hang it (Beomaster + Beocord)?  I seam to remember some where that you can mount it flat against the wall, or at a slight angle.  I also read and notice in images the cosmetic cover that hides the wiring.
I am guessing these are hard to find these days.  Are there plans/drawings for these brackets and covers?  Does anyone have one they can photograph to at least give me an idea of how to make one?
Cheers!
Hello Jamian,
If its anything like my 4500, yes you will need some bracketry. I would guess the covers to be more difficult to find than the brackets.
I'm an automotive audio and acoustic engineer. I design loudspeakers and full sound systems for new automobiles. I also dabble with studio, consumer and pro audio projects from time to time.
