Beosystem 3 with TV + Projector
Hi everybody,
I have a Beosystem 3 connected to a projector, and it is working well.
Today I want to add a second Display : a TV (non BO Product) - as the BS-3 has 2 outputs available.
So I reconfigured the connections of the BS-3 : Display 1 as Generic TV and Display 2 as Projector.
Now that the cables and connections are done, what is the best way to configure my Beo 5 (or Beo 4) to switch from TV to Projector ??? I have no idea how to do this... Is it related to the LINK options ??
Thanks for the help !
Olivier
Normally to switch between tv and projector, with a beo 4 the command is list till format appears then press 0 this should shut down the tv and turn on the projector, you might need to configure the settings for the cinema timings on the beosystem 3. If you have a beo 5 then the command is cinema but this would have to be programmed into the beo 5. This is normally done by the dealer. Unless you have the software. ;)
Thanks a lot !
Works really great like this !
Olivier
