Can anyone please help me with the pin layout for the RS232 connection between the Beosystem 3 and the Beovision 4 (with camera) ?
I already tried a straight cable and a null modem cable but still no luck. The screen doesn't power up and is recognised in the Beosystem 3 as a Panasonic interface TY-FB9FDD, which is simply the DVI interface.
When I use a Panasonic remote to power on the Beovision 4 (in the left bottom corner), everything works. So, I'm suspecting the RS232 cable.
Any help is welcome.
Beosystem 3 - RS232 pin layout to Beovision 4
These are the connections/layout for the BV4 mkIII (with camera) RS232:
Make sure you short pins 7&8 together - the beosystem won’t send commands otherwise.
