Beosystem 3 Mark 4
A  little question to the beoworld members
I have beosystem 3 mark 4.
is it possible to update its software so it can be decode Dolby Atmos Formate 7.1.4.?
currently  its only support Dts H d 7.1.
Thank you
You don´t have Mark 4, because it does not exist. The last Beosystem 3 version is a Mark 3 with 3D-capability. This system support Dolby Digital 7.1 and DTS 7.1 and multichannel PCM 7.1. It does not support Dolby True HD and DTS-masteraudiio decoding. And you can not upgrade the system to support Dolby Atmos.
The newer Beosystem 4, support exactly the same codecs as the former Beosystem 3.
Regards
