I have hooked up the Beosystem 3 to a Beovision 4 . When powering up, a green LED on the Beosystem is on for 30 seconds and then switched OFF again. At this time the Standby RED LED on top of the TV (Link eye pcb?) is lit steadily on.
My problem is that I am not able to switch on TV and don't know if I have a fault or not.
Pressing any button on the Beo4 remote makes no difference.
What I did so far after carrying this heavy beast to my workshop!
* Replaced IR sensor (used a TSOP7000 455Khz). I have checked pulses with the scope and seems responding to Remote .Tried also to connect a seperate IR-IN using 3pin jack plug as described here:http://www.beoworld.org/beotech/ir_eye_wiring.htm
* Switched ON the TV with a panasonc remote control (from the hidden slot bottom of TV). Tv is working fine. I have connected my laptop and I can see the picture fine through the DVI-D Iinput.
* Checked serial cable . pins 2-3-5 to pins 2-3-5.
* Checked IR-In ( RS232 connector) to Link eye PCB. I have continuity through all pins.
* Left units hooked up overnight on standby just in case needs registering ?? not sure if makes sense but found it on manual.
I am really stuck now. 🙁
I have learned that there is a pin code and master code, but I assume that a menu should appear on screen where I can see what I am doing. Thee is no o/p thorugh AV1 or AV2.
Last: Where can I get furhter technical support ?
Any type of help is welcome!
