Hello and first of all, scuse me for my bad English.....
I have had a wonderful Beovision5 from year 2002 but it has dead some years ago. Then i bought a Beovision 9 and i have put my Bv5 in garage waiting for repairs.....
Some months ago, i have had in my hands a Beosystem3 Mk1 and i started the job. I want to use Beosystem 3 to drive my old Beovision5.
I thought it can be simply but..... it is not at all!
The first thing is setting up the Bv5 plasma monitor.
I have connected Dvi "Display1" on Beosystem3 to Vga on Beovision5 plasma monitor. Then, i have connected Serial "Monitor" on Beosystem3 to Serial on Beovision5 plasma monitor.
I obviously did setting up "monitor" on Beosystem3 setup-menu (tryed every possible setting about "Beo monitor").
I have spent many and many hours about this thing, but it seems realli impossible........ I have two giant problems.
The first problem is:
When Bv5 plasma monitor is "on", it seems to "disturb" ir signals........ I press keys on Beo4 remote, but they are often not recognized....... When i cut off power and so turn off Bv5 monitor, ir signals are correctly recognised.
The second problem is:
It seems impossible to drive monitor functions "On Off Bright Dim Colors"...... I have connected the monitor via a "null modem cable". Not work. I have tryed to invert pin 2 and 3. Not work........
I am a little tired because i have spent many many time about this thing and i have had no success..... so i am here asking to you if someone know a way to do it.
I was considering idea about buying a new monitor and controlling it via Lintronic, but i woud like to use old Bv5 plasma monitor.......
Can someone help me suggesting some way to do the job?
I hope you have understand me because i know my english is very bad.....
Thank you!
Ema from Italy.
