Isn't that because you require speaker 5 for the surround?
I am using the HDMI only and the surround is fantastic. Think i have only tried PCM with the Playstation 3.
I have a playstion 3 plugged into my bs3 only with an hdmi cable I have just put in a DTS DVD and selected the DTS track , I am hearing beautiful DTS 5.1 with no sp/dif cable. I can confirm this by looking at the PS3 display which says it is playing DTS 5.1, and the BS3 sound menu is stating Multichannel PCM 5.1 which makes sense.
I agree with Corvin, you only need an HDMI cable. Only other thing I can think of is as of BS3 sw version 2.7 you can choose where the sound comes from either hdmi or another input.
Cheers
Peter
Thanks Beonut, maybe it was the software version that was causing confusion. I have 2.7. (I wish B&O would provide a changes list fir each software version)
I had originally bought a optical to coax converter for the Playstation but realised that it was not needed.
I have a new BeoVision 4-65 (Colour Management Version) being driven by the BeoSystem 3, connected is a PS3 and a Sky HD Box.
What settings do i need to set my PS3 to as the picture isn't as good as it could be? Do i need to do anything to my BeoSystem 3?
Many Thanks
Sony BDP-S300 (I don't really know market specifications...). We use two in our store, plugged in two BeoSystems 3. The connections are: HDMI & IR. The integration is total & perfect: we control them with Beo4 via STB-Controller 🤒
355f:
Please can anyone advise of a blue ray player that works with beosystem 3 and what leads are required? is it just hdmi??Will BS3 control the blue ray via beo 4 or is that to much to ask! any issues I should know about or any exprtise--- feel free
the SDP300 is a first generation and not profile 2 compliant- it also takes and age to load anything- sont have just scrapped it
