Please can anyone advise of a blue ray player that works with beosystem 3 and what leads are required? is it just hdmi??
Will BS3 control the blue ray via beo 4 or is that to much to ask! any issues I should know about or any exprtise--- feel free
*need the SP/DIF connector*
With HDMI ????
I am using a Playstation 3 with mine. I have my beo4 controlling it in a limited fashion as the ir control on the playstation is not very elaborate.
Very happy with the sound and picture, just use the HDMI of course and watch in uncompressed format where possible.
From what I read on the subject, decoding of Dolby TrueHD and DTS-HD soundtracks is done by the player itself. The digital output format should be set to multi-channel PCM, which the Beosystem 3 supports (according to one message here). There is no need that the decoding be done by the A/V processor itself.
Best regards,
Jean Vezina
