Hi all,
having the BS3 in storage for long time and now I want to set it up.
BS3 with latest software connected to a Panasonic VT65 plasma. Sources Technisat SAT receiver and Apple TV HD.
Actual problems are:
Picture on the TV is quite dark as long as the sources comes through BS3. If using the integrated SAT receiver of the TV picture is quite bright.
The picture sometimes stutters.
The aspect ratio sometimes changes although source doesn't change.
Can't turn on/off Apple TV HD. All other Apple TV functions are ok. PUC 2.60a is installed.
Slow startup of BS3 itself and devices controlled via PUC. For example, starting BS3 takes 10 sec. and after that you have to wait another 5 secs or so until the startup command will be send from PUC.
Any knowledge for solving the problems is appreciated.
