Hi all,
I have a BeoSystem 2500 (type 2606) which does not tune fm stations very well. The symptoms are:
Very low volume in FM only, in AM mode the volume is normal.
Not detecting any stations with automatic scanning. If i search manually, i hear the station but at low volume)
Not detected stereo in any radio station.
I have the fm antenna connected, the fm board in service position, and do not see any bad capacitor or visibly bad component,
I measured the voltages and appear to be correct (+5 V, +15 V, +30 V).
I appreciate if someone guide me to other tests, to find where is the fault.
Thanks in advance.
