Beosystem 2500 / Beosound Overture Light Bulb
dsid2000 wrote:
Hi Leslie and Max,
Thank goodness I'm not the only one struggling with this problem.  I called a B&O repair center and they didn't have the part nor could they provide a part number.  To verify that the bulb is out, I followed this youtube video minus the laser removal.
The part number is available in all the service manuals!!
I found it!!!
I called a B&O repair shop near Atlanta GA and the great guys there hooked me up!  For a light bulb it's a bit pricy but there aren't many choices $12.33 + $2 shipping.  This is the light bulb + circuit board so I must unsolder and resolder 2 wires but it seems quite easy.
Part #: 8230100
Modular Electronics
P{ease report back with the result, do you change only one or all 4
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
So any news regarding bulb replacement?
joeyboygolf wrote:
Good  Luck finding out, I never did. In the end I bought the spare part from B&O. They are sold mounted on the little pcb and are a HORRENDOUS !!price
I just got off the phone with Benny Amina @ Modular Electronics.   He said a 12V / 70mA bulb would do the trick, which I found
That looks like a LED lamp. I think you need a filament lamp.
That's correct and quite easy to replace.
?  I see no indication that it's LED.
Leslie, are you saying this bulb is ok?
It's not a led, just an ordinary light bulb. Shall I send you two for free?
It's not a led, just an ordinary light bulb. Shall I send you two for free Bob?
