Beosystem 2500 / Beosound Overture Light Bulb
Hello all,
I own a B&O Beosystem 2500 (aka Beosound Overture) and one of the 4 ambient lights surrounding the CD and tape player is burned out.  I verified this by taking it apart and indeed the filment is detached.  Does anyone know what kind of light bulb I need and/or who may sell them for the system?  I assume I can learn how to unsolder the light bulb and reattach a new one.
Any assistance would greatly be appreciated.  My system is 20+ years old and I'm graceful that something so minor has happened but it really deters from the attractiveness of the system.
Thank you very much!
David
Good  Luck finding out, I never did. In the end I bought the spare part from B&O. They are sold mounted on the little pcb and are a HORRENDOUS !!price
Well, last year after Xmas has ended I bought several Xmas decoration lights quite cheap and maybe I can use these lightbulbs instead of those overpriced prices B&O is asking! Let's see how that works out!
Does anyone can help me with replacement of the bulb? What i have to do step by step - any advice,or support? It seems to be covered by electronic board...or how to call this ;-)
Thanks in advance!
Max
It's just a little PCB with 2 tracks on it to keep the lightbulb in place. Nothing special, however I would advise you to keep the tiny PCB and replace it with an alternative lightbulb.
OK, thank you for advise. But how to get to the bulb inside Ouverture? It seems to be covered by some components. Especially the bulbs dedicated to light up the tape are hardly accessible in my opinion...
I will post a pictured guideline on your thread how to do that as soon as I found the alternative lightbulbs. Probably this weekend! Cheers...
Great! I'm looking forward!
Hi Leslie and Max,
Thank goodness I'm not the only one struggling with this problem.  I called a B&O repair center and they didn't have the part nor could they provide a part number.  To verify that the bulb is out, I followed this youtube video minus the laser removal.
http://www.youtube.com/watch?v=bcrPJcZOwfg
Leslie, I would very much be appreciative if you can determine an alternative bulb to use and how to properly remove and reattach a new bulb.  B&O certainly doesn't make it easily repairable.
Thanks and happy holidays!
I saw and forgot that video! Pretty good, I like those kind of instructions, saves you lots of bla bla..
The first part shows you how to remove the frontplate in order to get easy acces to the lightbulbs.
I hope I can find a cheap alternative for the bulbs and will post my findings!
Happy Xmas holidays to you as well...
