I have a question about the Beosystem 1, and I'm sure it's the same for the Beosystem 2.
My BS1 isn't turning on the BV4 screen, and I tried all the usual Control/Data codes 556, 559, etc.., I even connected the BS1 to my computer to read the codes it's sending, and it looks like it's buffering the control codes, which is causing a problem.
Using hyper terminal, connected directly to the BV4, I can send CTRL-B, P, O, N, CTRL-C, and the BV4 turns on right away, and the same but code POF , turns it off right away. And I can do it multiple times with no issue.
The BS1 turns the BV4 off fine, but won't turn it on, sometimes it does though. I see the PON code being sent from the BS1, sometimes. It looks like it's buffering and sending all the commands at the same time. Sometimes when I press the standby button on the Beo4, it turns on the BV4.
Could I be having an issue with one of the modules in the BS1? Or could it be something else? I have 2 BV4's and it's doing it with both.
Any help would be greatly appreciated!
