Hi guys, new to the site as I recently bought a Beosound5 which I am delighted with, it's a 1TB version, I am having major problems with the IE on it not resolving the DNS so I can't get to any web addresses, however within a command prompt it resolves URL addresses fine when I ping them. Subsequently it also does not recogonise CDs when they are inserted into the attached CD ripper. Anyway, I thought that I would explore upgrading the XP OS to a newer version if possible as a first step? Has anybody done it? Thanks
Beosound/Master5 Upgrade OS from XP to vista or beyond...
The CD ripping service is no longer supported, you can only use the device as a CD player.Hi guys, new to the site as I recently bought a Beosound5 which I am delighted with, it's a 1TB version, I am having major problems with the IE on it not resolving the DNS so I can't get to any web addresses, however within a command prompt it resolves URL addresses fine when I ping them. Subsequently it also does not recogonise CDs when they are inserted into the attached CD ripper. Anyway, I thought that I would explore upgrading the XP OS to a newer version if possible as a first step? Has anybody done it? Thanks
I would be surprised if upgrading the OS is possible. There are custom drivers and also some weird things B&O has done to lock down the system - that is, to replace the disk, you either must have a bit-for-bit copy made before the disk failed, or use a proprietary toolkit to rebuild the disk. It's not just a standard computer running a standard OS.
Two years ago I installed a Windows 7 Embedded version on a Beomedia 1. It actually did run, but still had some issues. Unfortunally I made a mistake and lost all partitions during reinstalling W7 Embedded to optimize the BM1...……... so there ended the project.I would be surprised if upgrading the OS is possible. There are custom drivers and also some weird things B&O has done to lock down the system - that is, to replace the disk, you either must have a bit-for-bit copy made before the disk failed, or use a proprietary toolkit to rebuild the disk. It's not just a standard computer running a standard OS.
B&O should be ashamed of themselves, the thing was advertised as a CD Ripper.
Totally disgraceful and short sighted.
Beosound 5 Head unit is beautiful, the BeoMaster 5 is an ugly dog of a thing both in looks and functionality.
