Beosound5 & NAS drive
Hi guys
I've been following this site for a few years now and you've always answered my questions about b&o before I've had a chance to ask them....
Until now
I've just bought a javelin s4 NAS drive with 2 1TB drives in it
When I select the NAS  I don't see any songs, artwork etc on the bs5 screen
The bs5 can see the drive unit but not the drives or folders
Any help greatly appreciated
B&o fan from down under
Hi glennp,
I must admit that I do not know that specific NAS.
You must make sure that the mediaserver (DLNA) is enabled/activated and that it is set to look at the folder with your music files.
What do you mean by 'the bs5 can see the drive unit..."?
Greetings Millemissen
Thanks for the reply Millemissen
On the BS5 I can select the nas drive in the music storage option but when I go to N.MUSIC I don't see any music , cover art etc
On the NAS the DLNA is on and when I select it I sees the songs I have loaded on the drive
Cheers
 Glenn
Hi guys
I did a firmware update and now it seems to be working but .....
There's always a but
The artwork is not showing correctly I have both embedded artwork and artwork saved as folder.jpg and neither show
All I get is the same default icon for all albums
Any ideas what I should be checking
Thanks in advance
Glenn
Please try "rebuliding the music server" on your NAS.
It might be called something else on your NAS.
It creates a new 'index' of the files to be used for DLNA players (such as the BS5).
