BeoSound3 Default Volume
Hi dear B&O Community,
I have 2 BS3s. Beside the fact that I had to replace for both the comand plate, I am facing the following issue: when trying to set the default volume level, I can not exceed 35. Any ideas?
Kind regards,
Arcarius
Hi!
You can set only 70 % of the maximum volume level which is 35/50.
JL
Many thanks indeed for your answer
