Hello everyone!
I am finally thinking of replacing my TV with a B&O-ish system. Would love to get the new Eclipse but unfortunately, I am sure it will be outside my available budget, so I am thinking of going the way of a Stage + TV + floor stand.
The questions I have are the following: Between the LG CX and the LG GX, will the GX integrate better with the floor stand and provide a "cleaner" look and more sleek cable management to the CX? Note that I have an open plan living room so the back of the TV will be visible when in use. Otherwise the two TVs are exactly the same from what I gather, and I think I prefer the CX design, when not wall mounted.
Out of the available floor stands, I am torn between the "legit" B&O stand that I really like the look of, but sadly is not possible to rotate (not even manually) and Spectral’s link that has sort of an Eclipse feel to it and is possible to rotate manually. I intend to get the Stage in Oak and I am concerned that having aluminum + wood + the black TV would look sloppy and confused as opposed to the cleaner (and maybe more modern-looking) B&O stand. I also think that the rectangular base works better with the angles of the TV and Stage. Does anyone have experience with either of these stands? Is it relatively easy to rotate/move the B&O stand from time to time (I want to be able to rotate the screen to sit close to the wall when I have guests or when not in use).
I don't intend to integrate surround speakers anytime soon, so the benefit of the Eclipse would be minor, I think. Also, when comparing the specs of the Stage to the Eclipse (see below), it looks like the two systems have similar drivers, with the Eclipse having 100W for the 4'' bass instead of 50W for the same driver on the Stage. Does anyone have an experience comparing the two? I guess the Eclipse would overpower the Stage, but probably not by much for a normal-sized living room (mine is around 30sqm)?
Thanks everyone for your help and input, much appreciate it! :)
Harry
BeoSound Stage
Speaker Configuration
4 x 4" woofer drivers 4 x 1.5" full range drivers 3 x 3/4" tweeter drivers
Amplifier
11 power amplifiers 4 x 50 watts amplifiers for the bass drivers. 4 x 50 watts for the full-range drivers. 3 x 50 watts for the tweeters.
Frequency Range
32 - 22,000 Hz
Maximum Loudness @1m (SPL)
100 dB SPL
BeoVision Eclipse
Amplifier
1 x 50 watts for centre tweeter 2 x 50 watts for fullrange driver 3 x 100 watts for midrange/woofer
1 x 1" tweeter 2 x 2.5" fullrange drivers 3 x 4" midrange/woofer
Frequency Range
34Hz - 22,000 Hz
