Beosound Stage Random No Audio for 1 Second Issue
Hi I have purchased Beosound Stage and using it for about 2 months or so. It is great but I have noticed that when I am watching TV, randomly audio will cut out for 1 second and then start playing again but no issue with Video and video keep playing when audio cuts out. This is same type of mute and unmute that happens when changing Listening Mode while something is playing.
I have Beosound stage connected to my Samsung QLED TV 2019 model via HDMI ARC. I have Apple TV 4K connected to Beosound Stage directly. This happens randomly and rarely maybe 3-4 times when watching a 2 hour movie so hard to figure out what is causing it.
I have a Stage as well. I used to have it connected to Apple TV 4K and Sony OLED using HDMI Arc as well. Never experienced the drop out. It might be one of your HDMI cables. I can’t think of anything else.  Also, the 2019 QLED might have the Apple TV App and if it does, you can remove the Apple TV and test to see if you get any drop outs. If yes, it is the Apple TV (which in this case seems to be the cause of the audio). Do you have audio on the Apple TV set to auto?
If you do a quick search on HDMI Arc issues you’ll notice that it is quite common and typically switching cables is the solution. Both Samsung and LG TVs have had issues with HDMI Arc audio.
Did you us the hdmi cable thay came in the box? Or your own cable?
So the Stage is connected to the TV using the HDMI that came with the Stage in the packaging. I used another high speed HDMI cable designed for 4K resolution to connect my Apple TV 4K to Stage. I view Sound Info on the B&O to confirm that Atmos audio data is coming from Apple TV and other times when content is not Atmos it receives LPCM sound data stream. Also when I ran the cable test between Apple TV and Stage on the Apple TV setting then it mentions there is no issue with cable and also I have transferring Video at highest resolution at 60Hz with HDR and also the Audio is sent as Atmos when available. So I doubt cable is the issue because if cable is causing the issue Video might also have issues and when the problem happens it only causes issue with Audio not coming out for 1 second.
So regarding HDMI ARC, this issue should not happen since the Apple TV is connected directly to Stage so it is getting the Audio data from Apple TV directly and it is not being channeled through the TV via HDMI ARC. HDMI ARC is being used to send audio only when TV is sending audio to it to play. So either Apple TV is not sending the audio for 1 second randomly or it is Stage that is doing something weird where it is pausing for one second before playing audio again.
I installer this with Lg c9 and Apple TV directly to the Stage.
i could not belive it was the cable betwhin TV and Stage. But it was, i change to the orginal cable that came with the Stage, and sound not drop out anymore. And the sound drop out was on Apple TV, internat sourche and set up box connected to the TV.
so yes, it could be problem with the cable still te picture is okei.
that was I Ask, becaus the customer have us and high speed cable with Ethernet, but not the cable that came with the Stage. The cable with the Stage is hdmi 2.1 and the other is not more then hdmi 2.0. And 2.1 is about the dolby atmos sound..
So this does not seem cable issue. The cables I have are HDMI 2.1 or better as they support 4K and brand new cables. One of the cable came in the packaging provided by B&O so understand that these cables are genuine and not the issue. Also upon raising the concern to B&O support team they and sending them logs and details via beotool app I got a reply as follows:
We have just been informed that a software update has been pushed to your Stage which might resolve the issue, please update your product to the latest software and let us know if this was successful in solving your problem. If not, I kindly ask you to try and replicate the issue (if possible more than once) and to note down the exact time when it happened (please make sure to include the time zone as well). Afterwards, I would need you to submit the log files through the Bang & Olufsen application by following the path as such:
Settings (cogwheel) > Products > BeoSound Stage > Configure > About > Diagnostics and Usage > Submit Log Files
I noticed I got the following update available 1.8.37758 and I had 1.8.37133 before when I was experiencing issues. Will update everyone if this solves the problem as for me the problem occurs when watching for a longer period of time and not quickly and as often. Maybe 3-4 times max when watching a 2 hour movie.
hi, I recently bought beosound stage. I have it connected to lg oled 65 cx via hdmi cable (supplied with stage) to eARC on tv. The issue i am encountering is that when i turn the tv on, the soundbar dies not always start playing the sound. I have to then put soundbar in standby via the mobile app. Btw when I do that, tv also goes on standby. When tv restarts, the soundbar starts playing sound, and is controllable using lg tv remote. Auto device detection, cec, simplink are enabled. Any ideas as to how this wake up issue could be fixed would be very welcome, thank you
I think you’ll find it may be due to the LG quick power on function ? This caused my TV dropping Ethernet connectivity - basically the TV has a quick start mode that doesn’t fully turn connections off or on fully and you may have issues.
Try with the quick power on option turned OFF and see if you still have the same issues.
