Beosound Stage Power Light
Hello everyone,
I bought a Beosound Stage today, it updated to the latest version and is working fully as expected. Except one small strange thing.
There are two lights on the sound bar, Power and WiFi symbol.
in all reviews and inline with my other products the lights should be white when in operation/on. Except with me the power light is bright red when the device is on. And turns off when in standby.
I googled around, but cannot find someone with a similar case.
 See picture:
Did you try the b&o app, there may be a software update. I think my M3's show a red light when they need to be updated..
I tried multiple reboots and using the app to check for updates but it says I have the latest version: 2.2.40830.245677440
Also tried factory reset etc.
Hi
I think it try to tell you that you are connected to WIFI but with "Wireless connection of poor quality"
No it is the power light that is red not the WiFi connection light. The power light should never be red only white according to all videos and reviews I’ve seen.
