Beosound Stage is an excellent value!
I received my Beosound Stage (smoke oak and grey version ordered online from B&O) and set it up just for music in my dining room area. Not only does the speaker look great but the audio quality is much better than what I expected at this price point. I am currently using it purely as a music speaker with AirPlay 2.
At the starting price of $1750 this is truly an excellent value. The build quality is top notch.
Fantastic. Can we have a pic please?
Glad to hear it 😁
Unfortunately I am unable to post any pictures. I have tried 🤷‍♂️ Anyway, I have it flat on a long side table. It looks great, but I am really impressed with the audio quality. I actually prefer it to my Mk2 A9.
How did you try?
You'll have to upload your pictures to Beoworld first.
Go to your profile: click on your name (upper right corner). Go to "My files".
Then click "Choose file" - a window opens, and you can search for the picture you want. Then "Add file".
Then, when you write a post and want to want to insert your picture- click on "insert media". It is as simple as that.
....or, click the Reply button, then Options, then Add/Update - and choose a picture following the instructions there.
In my case, I was able to upload the files to my account on Beoworld but then when I try to add the browser just hangs and does not show my images. I’ll try again.
Same here on Safari for mac os. Then:
- Open your image on a different browser window.
- Right Click and click on "copy image link" or similar (I'm on french OS);
- Back in the compose window, click on the "insert media" icon (the green little movie frame).
- Choose "from URL" and paste the link in the relevant field.
Done!
For single image, just follow MM procedure. For multiple, follow mine.
Hope this helps.
Great to hear this. Are you using it as a standalone without a screen?
Yes. I was planning on buying a BS 1 and BS2 but then bought the BS Stage instead. I might hook it up to a screen in future. But even as a standalone speaker it sounds really good.
