BeoSound stage
Hello,
Quick question. Is the BeoSound stage always on like a Sonos speaker?
I’m considering putting one in the bedroom with a Oled tv but mainly so I can play music from my phone without having to power on any devices. This is easy with Sonos and I have a few around the house.
I’m otherwise considering the Sonos arc as it is always on.
Yes you can!
I have one for sale😕
Look att Blocket
Yeah, all NL speakers are always "on". Stage is always ready to instantly play music. No need to touch the speaker itself or use a remote.
mr_anders_son wrote:
Yes you can!
I have one for sale
Look att Blocket BeoVision Eclipse 55"...BeoLab 5 FRONT....BeoLab 4000 as REAR....BV5 HD....Beoplay V1-40....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beosound Stage....Beoplay S3....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H9i Rimowa....6 x H6....Form 1....U70...
Looks nice but not the color I’m looking for primarily but might change. My bedroom is all warm colors so. But also it has to match a tv.
So much to consider 😂
Excellent! Just what I want.
And probably it works well pairing Sonos and BeoSound over AirPlay for tandem playback when I have parties and need music in my whole house :).
Yes. I used my Stage only for music. Right now for my bedroom, I have a Core so that I can listen to music without turning on the. projector. The audio from the LG projector is connected to the Core. The. Stage. can do the same thing when you use AirPlay 2 - it won't turn on the TV. The Stage is pretty good as a music player.
I used to have a whole house with Sonos so I know how they sound. You won't be disappointed with the Stage.
When I had the stage in the bedroom on a shelf, the white status LED is pretty annoying and very bright! Maby there is a way to switch it off, but be prepared to have some black tape handy :-)
The lights can be switched off now!
Today I had new software for my Stage (updating from 1.8.xx to 2.0.xx). Anyone got any info on changes apart from the improved multiroom?
Yes you can!
I have one for sale
Why are you selling so soon?
Just curious 🙂
Hello kawo,
via BeoApp onto Stage, then settings you can switch off lamps.
My Stage in Bedroom lights the hole room very well, too. 🙂
So i set it off.
