BeoSound Ouverture Repair
Hi Peoples
Anyone know a good place in the East Midlands where I can get the front glass doors repaired?
The left door has dropped on one side and both doors are not opening. They are getting stuck. I can open them with my hands though. There is always a clunking sound...
Hi kiran
open back of the unit...take srewdriver ..fix it :)
no problem.. :)
The left hand door looks about ready to fall off sir!
Has it perhaps become dislodged from it's guide/holder?It should simply snap into place.
The clunking sound is that of the safety clutch,which cleverly prevents the motor control becoming damaged if the doors are impeded.
Be careful about attempting any adjustments,as the door alignment is quite fiddly to get "just right",and being B&O it has to be that?
Regards,
Nick
