Beosound Ouverture output left speaker weak
I have a beovision 10 with beolab8000 speakers. The soundfrom the beovision is perfect via the speakers.
The Beosound Ouverture is connected to the Beovision by a brand new powerlink cable. The sound from the left speaker is weak (rihgt is o.k). The problem is not the Beolab or powerlink; it has to be the Beosound. Who can help me what to do. Who can send me an electric schematic from the audio output. I downloaded the service manual from this site, but it is hardly to read what figure output is written.
Thnxs.
Are you sure you have connected your Ouverture with the BV10 via a Powerlink cable? You have to use a Masterlink cable. The Powerlink sockets are all outputs , not inputs.
Stefan
I'm sorry. I mean masterlink instead of powerlink.
I'm not sure if this is effective in your setup, but did you check if your balance of your Ouverture is in the middle?
Balance is in the middle. When I connect a headphone to the headphone out on the Ouverture the sound in the headset is o.k. So then the sound on left and right earphone is real stereo.
Connect the Beolabs directly to your Ouverture. If the sound is ok, I`m quite sure, the ML cable is faulty. The Masterlink has balanced signal, thre wires for right channel (2x signal, 1x ground) and three for the left channel. If one wire is missing, there will be a signal, but less volume and bass.
See also beotech Masterlink wiring.
Stefan
ML cable is already replaced. (see 3rd reply)
But I think Stefan is on the right track. It is possible that one pin in the ML-socket is bend to the outside, not making contact with the ML-plug. Likely this happened on the BV10, because that socket is harder to reach than the side on the Ouverture. You might want to take a look at that.
With Beolabs direct to Ouverture the problem is still the same, so I think it has to be the Beosound Ouverture (output on headphone is o.k.).
I think so too. Maybe a contact problem with the headphone socket, or the mute relay not working properly. I`d plug - unplug the headphone several times, and if this doesn`t help press the mute button several times. just a guess....
Stefan
hi
had this issue aswell. Redid my ML connection in the junction box and that solved the problem. try borrowing a new ML cable and connect the tv and BS directly...
