Beosound Ouverture & Beocenter 2300
Beosound Ouverture & Beocenter 2300.Can you use the same CD mechanism?
Most of the times that's possible for the older mk1 version of the Ouverture. But it can be converted to a newer mechanism (used in the mk2).
The newer mk2 version of the Ouverture has most likely the VAM1255 laser and can't be replaced by a cheap ebay version.
You first need to know which laser has been placed inside the Ouverture (or 2300, the one which needs repair). For that you need to dismantle the Beosound.
Depending on the age, the laser movement is a straight line or an arch...
