Hi Chris, thanks for getting back to me :-)
For sure Moment ponishes you right away if it's up to B&O ruels :-(
a) The range of the Access Point cover the hole 2nd floor and can even boost through to 1st floor (n router)
b) My router is Arris WTM652g (g router Claro intenet providers supplied) & the Access Point (n router) D-link Dir-655B1 they are wired up ethernet - ethernet via Cat5 cabel) DHCP is disconnected & the IP address on the access point have been set outside the Router primary DHCP addresse range.
c) I'm of course not sure everthing have been set correct as I'm not a computer nerd :-) and just follow network setup instructions found on the internet, with the setting above I actually had moment running on 2nd floor but found later on that Jukebox loos the connection on 1st floor after a while & same time the BeoMusic app did not work moving from one net to another
d) Where Moment is located is I have a signal strenght around 80 from the Router & around 60 from the Acces Point, but I have notice that from time to time the Access Point actually mange to go higher in signal than the Router signal
If you got time I could send you a PDF of all my setting & I do not mind pay for your time if you think you can get it up running.
Kind regards
Christian
