Beosound moment question
hi all, just in the middle of a full house refurb and trying to get my cabling right! If I have a Beogram connected to my moment, can I then share the output with the other multi room speakers across the house?
Yes, indeed you can!
Yes, if the Beogram is a later model with a built in phono pre-amp, then you just need this cable to connect it to the Aux input of the Moment:-
link
If the Beogram doesn’t have a pre-amp, you will need this pre-amp kit instead, which comes with all cables needed and full instructions, ready to “plug and play”:-
Thank you both! Just ordered some longer cables actually Steve! As soon as I pick a beogram up I’ll be in touch for what I need.
Thanks James!
The cables are ready to post in the morning, please ask if you need any further help.
Kind regards, Steve.
