Beosound moment light bleeding
Hi guys, I received my besound moment few months ago but I was in the middle of relocating for good. So yesterday, I unboxed everything ( from dealer ) and to my surprise the screen has clouding and light bleeding on the edge.
Attached some pictures for your reference. Is there anything I can do about it? Is this even normal or does it qualify for repair ?
Engineering since ever...
It does qualify for repair. I’ve never seen that on mine so far.
I bought a BeoSound Moment.
It was a moment of madness.
Would you please elaborate?
I have two Moments; one does this, while the other does not.  I moved the one with the bleeding to the office where I never operate in the dark.  With room lights turned on it is not at all noticeable, so I haven't concerned myself further.
I’ve checked mine and no actual bleeding noticeable. When I made a picture, slightly bleeding is showing.
I had my tablet replaced after it was first only repaired. After the first repair the screen was bleeding more, particularly when I twisted the screen very softly (holding both ends and turning it slightly counter wise). Turned it in again as the screen was fixed to tight into the outer case. Fixed the issue but after a while the tablet died on me and was replaced with a new one.
If the bleeding is noticeable with the naked eye I would return it to get repaired.
Hello,
Dealer was able to replace my beosound moment. Now I have a bigger issue. I can't get it to work. I tried resetting and restarting but I'm getting the following issue although I have a working internet connection both through WIFI and LAN.
