Just got a beosound moment. I'm trying to connect to my non B&O amp using the RJ45 to phono cable, and during first set up, I select the wired speakers option, but the Moment says it cannot detect the wired speakers.
So now I'm stuck on set-up page. I can't even update the firmware as setup is not complete, What can I do? I even tried selecting the wireless speaker option, and tried to connect to several bluetooth headphones, but none would connect.
The setup can't continue unless speakers are selected.
Is there a way to upgrade the firmware manually via USB stick?
If I am forced to buy B&O speakers, what are the cheapest B&O speakers, new or old, that have the RJ45 connection that will work with the beosound moment?
Any help appreciated.
