Beosound Essence syncing issue
I have connected a Essence MK2 with my LG C7. I have tried both Bluetooth and line-in connection.
I have severe lip-sync issues. Is there a setting for adjusting this?
Never mind, found it for line-in.
Is there some way to disable the delay for Bluetooth?
Not that I know of.
Did you eliminate the delay through the line-in? How are you planning to do volume control?
I eliminated delay through line in.
I adjust volume from the tv.
Do you use the LG remote or did you pair a BeoRemote BT?
Is it possible to pair a Beoremote One with the LG tv? I had a friend try, but he couldn’t do it.
