Beosound Essence Remote an BS 1
I have two BS 1 each paired with a BS Essence Remote. When paired it works fine. Unfortunately both lost their connection after some days, so that I have to re-pair them.
Does anybody else have this experience? Is there a known fix?
Thanks for help
I have the same on my core, I have 2 essence remote paired to the kitchen but hopeless. Every 2 weeks, delete, unplug mains, plug mains, pair....😕
No worries, you get used to it, my wife starts laughing at me, cheap crap she says.
Same problem for me with A9Mk2. Welcome to the “luxurious” and “lifestyle” world of Bang & Olufsen. ;)
Hi.. as i know they still work with this. And both bs1 and a9 will Get new software in this week. If everything in the Quility test work good. So maybe they will fix this problem:)
And if the fix is similar to the Essence "solution", you might get a nightly "plop" or "boop"... which I guess I prefer to weekly power cycles.
I've had the same problem with the BS1. The really big problem with the BS1 is that a power cycle isn't as easy as use unplugging and reconnecting the power cable. Since the BS1 has a battery reserve, you must press the button on the bottom of the BS1 to do a power cycle. As the buttons are not clearly labeled, I must get out a flashlight and my reading glasses to do this.
My solution has been to use a Lutron RadioRa2 keypad via the BLGW. I have more control over the BS1 by assigning and labeling buttons for specific sources and for JOIN and STANDBY. I use this much more than I use the Essence remote.
It's also a shame that B&O hasn't expanded use of the BeoRemote One for more BT products.
Lutron is a workaround ... but it’s not the essence control, which in my opinion is very smart 🙂 ... if it works 🙁
UPDATE:
With yesterday's firmware update we CAN now pair a BeoRemote One BT with audio products. I just paired it with my BS1 and it works great! Let's open the connection stability is good and hopefully improved for the Essence remote as well.
