BeoSound Essence Mk2 final sw version number? 2.5.55678(170713653) ?
Could you please confirm the current sw version is 2.5.55678(170713653) ? Is it fair to assume that Beosound Essence Mk2 software is no longer updated?  That said, if I were to obtain a unit with older software, is it still updatable? I ask because of the sad case of the ML/NL converter: we have a final version, but if you failed to update it when it was still updatable… you are out of luck forever. Thanks in advance,
My Essences are at… …and that is the latest it has gotten with Autoupdate set to on. I do not remember when it was done. P.S. A bit of a mystery, though, is that Beotool shows something different.   When searching in the app, it says ‘up to date’ 😏 No big deal for me - my Essences do what I expect from them respectively need. MM
Release notes here:
Thank you all!  So, the sw is still updateable, and furthermore, an update was issued as recently as a few weeks ago!  Most excellent news. Guy —If I get one of these, my plan is to test it with my “JOIN”-type eye that works perfectly with my ML/NL converter, in order to decide whether to buy one for the Beosound Essence.  I’ll post my results if and when it happens.
Looking into it more closely, it is funny……my other Essences are up to date and the one, from which I posted the screenshot, is not. They are all set to auto update. So why do they have different versions? However - as I wrote - they all do what I need from them - so there can’t be much difference or improvement there. P.S.  No experience here with ir eye - all my current stuff is NL-based and BROne/bluetooth controlled. MM
I checked back through my emails because I remember B&O tech support telling me about a new SW update in one of their emails about IR control.  Their email was dated 3 July, and said that version 2.6.56017 had just been released.  I think that my Essence updated to this even later version, and will check later today. EDIT:  Here's confirmation: Screenshot 2024-08-01 at 08.25.56 So I think that software release link that I sent earlier (link) actually shows earlier releases, rather than the  latest one - the same data as the 'earlier releases' option on the app.  It's a shame that we can't then see the release notes for the latest release. (As and aside, you can see a full list of B&O SW releases (not just Essence) here:  )
@Guy So you have got a later version for your Essence, than I have on mine (and one of those is even far behind, although it says ‘updated’). It is ‘weird’……if I may say it with a modern buzzword 🤣 MM
