Beosound Essence Mk2
Hi
I have upgraded all my link rooms to Beosound Essence Mk2
Does anyone know how to set like bass, treble and mono/stereo ??
The Setup app has none section for this.
I have asked the Support in Struer 3 times now, but gets no response at all (very bad support !)
Best regards Rudi
Rudi, who have you tried to contact? My experience is that when you contact the correct department, you get a very fast response and help. Have you tried your dealer?
I would have thought changes to these settings would be done via your streaming source (Deezer, Spotify etc.) which is where I do it for my A9 etc. I'm not sure you can do this directly as an Essence string.
Dave.
Hi Dave
It is sent to bogo@mailgb.custhelp.com, the mail address that responded to my request at the web.
br Rudi
Hi Rudi,
at this phase the BeoSound Essence does not have any options/settings for manually configuring the bass, treble, etc...
Br,
Petros
Best use the webmail on the B&O website - costumer service -> contact.
How do you know the mailadress, when you did not get response❓
Did you ask your dealer the same question?
As I said though, my understanding is that you need to do this via your source, not the Essence.
Dave.
I would not be surpriced, if it can be done by connecting an ir-eye to the unit using the beoremote.
I did use the web - the mail was shown in the auto response
Well, the source is the Essence
OK, I'll rephrase - from the control device that you use e.g an iPhone, iPad etc. you can change all settings from there, my understanding is the Essence per se can't do that.
Dave.
