Hello,
I am no specialist, but here are some of my quick remarks as an Essence MK1 -owner since 2014.
1. Most of the functions that you described in your post were done previously via BeoMusic app, which is at the moment defunct.
2. Remote control only gives you the control of volume and turning music/device on and off.
3. Spotify Connect does not support Essence (at least last time I checked). I use AirPlay, which seems to work okay.
4. This is not a part of your post, but which annoys me a big deal is that there is a failure in RCA -input that seems to be a common problem in MK1. Meaning if you hook up your TV into the input, the whole system comes unstable (gives distorted noise and/or does not respond to commands).
To me, the restricitions of Beosound Essence Mk1 were highly disappointing, it was clearly a test project for a streaming hub for the manufacturer. I have had a number of problems with the system (had it serviced during warranty and also replaced once), and though I am a fan of B&O speakers I must say that this system has been a disappointment!
Having said this, I am thinking of swapping the system to Beosound Core, that should be now their project for a longer time development. I have been promised by the dealer that it should make all the things that Essence should have done (and which maybe Essence MK2 has also done, but not MK1). Perhaps I am crazy, but I think I give it a try since I enjoy my Beo speaker set a lot!
Anyone online, I also welcome all the opinions and reviews on Beosound Core!
@qqquickkk I feel for you in this Essence deal, I hope you get it working in some terms or perhaps can return it. I am afraid of trading my MK1 to anyone, and probably won't, as they probably want to return it. Shame really.
