Hello all,
When I want to use Beosound essence as master, the sound is too louder in the speaker and disconnected them.
What can I change ?
Hello all,
What can I change ?
If you have access to a iPad and download the BeoSetup App (soon to be discontinued), you gan setup the Essence to a) give maximum volume (0-90) and b) show default start-up volume.
I assume the Android app does the same.
... BeoSetup App (soon to be discontinued)...
Sorry to hijack the thread, but will the BeoSetup App be replaced with the "X" app, or has B&O decided we don't need to configure it anymore?
Thanks,
Stan
In the X App, Settings >> My Product >> Select Product >> Configuration >> Sound
In the BeoSetup App (still available), select product and go to Sound
