Beosound Emerge
steve1977 wrote:
As long as i use google home to create a stereo pair, i should be able to use roon to CC to this google created stereo pair. Wouldn’t know why this is not possible as roon is just relying on google as well.
Roon will traffic manage both CC speakers to play in sync. But that’s not a stereo pair , with left right separation
Does anybody know if the non GVA versions have the same touch buttons on the command panel then the GVA version? I'm asking this because of the microphone button.
I know. But you should also be able to play directly to the stereo pair if you include the pair as a speaker in roon. google can create the stereo pair. i haven’t tried, but don’t know why it shouldn’t work.
Got it - might work if the speakers have been setup as a pair in GH.
Will depend on how Roon sees them in its UI.
I don’t use GH myself so not something that I’d readily test
Wait, can't Roon do separate DSP filters on both channels for any zone, such that you can filter out all frequencies from the left channel on one "zone", and all frequencies from the right channel, on the other "zone"?  I thought the only problem might be that "play in sync", pushing via CC rather than RAAT, wasn't quite close enough to guarantee non-phased output between zone Left and zone Right... Is it bad, or does it work OK with CC (but without GH)?
Quite rare to see an electric cord in a B&O
Promotion pic 🙂
Sure, I think I think you're right on that front.
But from what I read, its not that perfect.
And moreover, its not really a native solution, when it comes to Roon doing CC stereo pairing, to me at least.
Promotion pic 🙂
...together with the most unlikely reading position!! I'd be surprised if she can see the text for her cheekbones!😁
Generic design like  I saw from many Wifi Routers Design out there.
Sure, but my router is lying flat....or rather hanging flat on a wall.
Just because it it thin and stands up does not make it a router.
It is in the eye of the beholder which associations one get looking at the BS Emerge I guess.
