Beosound Emerge
Hi, does anybody have infos about the future Beosound Emerge?
https://fccid.io/RR-BOA-Emerge
The rumor I hear is that it will be something in the same segment as M5.
I was hoping some magical movement with such a name... So it will be below the Level in the range.
Emerge looks promising. Somewhat a cousin to Level. Heard rumor that launch is mid April.
Absolutely, an "Emerge" ought to be a soundbar with rising acoustic lenses, á la Audi A8(D3) dashboard!  Alas, I don't think we'll see it: Troublesome little buggers get stuck; worse, the software tries to diagnose failure & immobilize, rather than strip a gear rising against an object. "Clear your codes, try again."  Someone on audiworld.com suggested Viagra!
It that is the expectation, you will be disappointed. No movements.
Some webstores already mention the Emerge: it will be available in Gold Tone/Light Oak (750 €) and Black Anthracite (600 €). Versions with and without the Google Assistants. All versions have wildly different stock dates, but the earliest mentioned is April 5 (!).
I heard a launch around April 14
matteventu wrote:
Do they also mention any specs?
Not seen any spec, but I think we can expect something along the lines of Beosund Level.
Emerge has a different formfactor from Level and not as many placement option as Level, however I think it will have a wallbracket option.
Gold Tone/Light Oak looks stunning.
Still not appeared... Any launch date infos?
