Hi, does anybody have infos about the future Beosound Emerge?
Beosound Emerge
The rumor I hear is that it will be something in the same segment as M5.
I was hoping some magical movement with such a name... So it will be below the Level in the range.
Absolutely, an "Emerge" ought to be a soundbar with rising acoustic lenses, á la Audi A8(D3) dashboard! Alas, I don't think we'll see it: Troublesome little buggers get stuck; worse, the software tries to diagnose failure & immobilize, rather than strip a gear rising against an object. "Clear your codes, try again." Someone on audiworld.com suggested Viagra!I was hoping some magical movement with such a name...
It that is the expectation, you will be disappointed. No movements.Absolutely, an "Emerge" ought to be a soundbar with rising acoustic lenses, á la Audi A8(D3) dashboard!
Some webstores already mention the Emerge: it will be available in Gold Tone/Light Oak (750 €) and Black Anthracite (600 €). Versions with and without the Google Assistants. All versions have wildly different stock dates, but the earliest mentioned is April 5 (!).
I heard a launch around April 14
Do they also mention any specs?
Not seen any spec, but I think we can expect something along the lines of Beosund Level.
Emerge has a different formfactor from Level and not as many placement option as Level, however I think it will have a wallbracket option.
Gold Tone/Light Oak looks stunning.
Still not appeared... Any launch date infos?
