Beosound edge or Beoplay A9 3rd generation
I am looking at buying either a beosound edge or beoplay a9 mk3. I’ve heard them both at my friends apartment which is a small room. I live in a house with a large living room of almost 50 sq.m
which would be the best option? I like to hear loud music and very varied music. My plan was also to connect it to a google home account so as to use the google voice assistant without having to invest in the 4th generation of the A9. I will be purchasing the item used.
thanks in advance
Paul
I love the A9. The sound quality is the best I have heard from a single speaker system. You can place it anywhere and it sounds great!
