Hello, I'm the proud new owner of a BS Edge.
I have some questions regarding the bass port. I decided to observe it as I can hear a 'mechanical noise' when I switch the Edge on or when increasing the sound level...
Is it normal to hear it opening or closing (light 'bzzzzz noise')?
When I start the Edge the bass port closes. I noticed that its movement is more slow when 'waking up from standby' (and the noise is slightly different as well) than when it normally opens - closes while music is playing. When getting in standby, it opens again and the movement is more slow as well. Is this the normal behavior?
Thank you for your help.
