I have 2 BeoLab 8000 active speakers and 2 BeoLab 6000 active speakers. I am planning to buy a BeoSound Core to do music streaming to these speakers. Can BeoSound Core stream to all 4 units? If only 2 can work at a time, can I use Chromecast Audio for 2 of these speakers and also stream/control from BeoSound Core? What is the easiest way to stream to all 4 speakers with minimal devices?
BeoSound Core working with Chromecast Audio device
The speaker towers are inherited so they are stand alone at the moment.
So using Chromecast Audio in one set and using BeoSound Core in the other would not be able to control both with one source? The BeoSound Core is pretty limited in controlling multiple active speakers.
Sounds like I can only power up one set at a time.
What if I only use Chromecast Audio on all 4 speakers???? Not sure if the sound quality would be good. This solution does not do the B&O speakers justice.
If both the 6000s and the 8000s are inherited then you are an, albeit sad, lucky man. So if there is no B&O source system to connect to, you could get two ChromeCast audios and plug them into the speakers via appropriate cables. Then use a device with Spotify (or whatever) to stream to either or both ChromeCast audios. So no need for a Core. If you already have the Core you can leverage its builtin Chrome cast and get a ChromeCast Audio for the other speaker set. You should be able to Spotify both devices by setting up a Google speaker group: Login to view imageIn the above the Sitting Room is the Core talking to the BL20s, and the Auxiliary is a ChromeCast Audio inputting into a BeoSound.The speaker towers are inherited so they are stand alone at the moment. So using Chromecast Audio in one set and using BeoSound Core in the other would not be able to control both with one source? The BeoSound Core is pretty limited in controlling multiple active speakers. Sounds like I can only power up one set at a time. What if I only use Chromecast Audio on all 4 speakers???? Not sure if the sound quality would be good. This solution does not do the B&O speakers justice.
Thank you for the suggestions. Will give Chromecast Audio definitely a try!
Happy listening!
Shouldn't 2 Chromecast Audio plus the appropiate cables be enough? ;)
If he wants to be able to supply all 4 speakers with the same audio (whole house solution) isn’t there something like this he could do:
core -> speaker set 1
network link -> ML/NL converter -> ML system (like a Beolink Converter? Or a cheap beosound 4?) -> speaker set 2
wouldn’t both speaker sets then be connected and drivable by the same audio?
