BeoSound Core (unpacking)
For what it’s worth ... not the most exciting product !
Login to view imageNot a pristine unpack as the store (Ben) and I had already had a go ... Login to view image
Ed. Looks good. What are you gonna use it for ?Not a pristine unpack as the store (Ben) and I had already had a go ... BeoNut since '75
It weighs almost nothing...
Even better 👍🏻
Login to view imageUnwrapped ... Login to view image
Snap out ... Login to view imageSnap in ... Login to view image
So there’s the unpacking, unwrapping, and snapping in ...What did NOT work was the power on, the flashing light, and the appearance on the BlueTooth list ...So I think I have a DOAAnd yes it’s lightSo light that I would almost believe that there is nothing inside !Back to the shop tomorrow [:\'(]
To replace the Essence which will go to another room. What I hope to gain is superior sound by using an all optical path for all my streaming sourcesEd. Looks good. What are you gonna use it for ?
Into shopShop checks things, no go, knowing other AU adapter plugs have had issues they deconstruct the plug, give it a wiggle, force it back, reconnect .... and voila a white light. So Home we did trot, did a re-snap-out, re-snap-in, white light, yayyyBlueTooth search, found BS Core xxxx, Connect, use B&O App, add product, select found BS Core xxxx, rename it, add WiFi and its password, allow google cast, all goodSoftware auto-updates, reboots, speakers go pop-pop we’re here 😁 Login to view image
