Beosound Core on/off feature
B&O Beosound Core
As regarding the newest Core does anyone know if it had an auto on/off feature when using an external source to the optical or line/in ?
I want to use an external source , a streamer, but want the Core to start when it senses an audio signal.
Thx
Yes it does
I have two cores both connected using optical and it goes to standby after 2-3 minutes. You can also make it go to standby from the app or Essence remote (if you have one).
