Beosound Core and Beolab 20
Hi everyone, I have a pair of Beolab 20 and I was wondering if getting the Beosound Core would allow me to adjust the bass level?
Thank you.
With the Core you can adjust bass, treble and set the loudness
Thank you. Do you know if there is a notable difference between getting the Core vs tradition AV receiver?
So bass, treble and loudness is possible, is that via beo4 remote? And, is it possible to also adjust left/right balance?
Thanks in advance
//Goran
The core also allows you to specify which speakers you are using
