Beosound Core - Airplay 2 update available
I have just now updated my Beosound Core to version 1.3.26460.41389907 and Airplay 2 is now available.
In my integrated BV11/Core configuration I had to disintegrate the Core before I was able to configure Airplay for multi room. Having done that I could integrate the Core again, and now I can use Airplay 2 on my BV11 speakers
Best regards Dyssegaard
Are you on the Beta track or have AP2 been included in the commercial release?
I’m not on the Beta track. The update was displayed in the Beotool today.
Not on my Essence (2nd gen) yet.
One question @Dyssegård
Are you still able to redistribute an airplayed source to (an)other NL device(s) - like we have been before?
Yes, I can redistribute Airplay to my M5 from my BV11/Core as before (no Airplay 2 on the M5 yet).
BeoTool shows the update available for my Core but not for my Essence 2nd generation.
The Essence is supposed to be in the second run (according to another thread, that I can’t find).
Funny - BeoTool and the app shows that there is an update for my M3. But it won’t let me update manually.
I guess I’ll have to wait and see, what will happen over night.
Rgd. the update of your M3. I had the same issue when I first tried to update my Core. I had to enter the configuration part for the Core and do the update from there. Maybe you could try to do the same for you M3.
That is what I did - you can not update from BeoTool!
Still the option of updating there does nothing.
Actually I am more interested in the AirPlay to NL distribution feature - if that is kept untouched with the new update?
Since I have no ‘only-AirPlay-devices’, AirPlay 2 won’t give me much improvement.
Sorry for not being more precise on how I did the update. Please see screen shot below:
I used the “Konfigurer” part instead of the
“Software” part.
Rgd. the Airplay to NL distribution. It’s working, but when I shift my music program (Yousee music) to the background, the music pauses. It didn’t do that before the update, and it is a bit annoying ...
